No power windows
Old Feb 5, 2014 | 04:08 PM
NorDakota's Avatar
NorDakota
Default No power windows
2000 Quad Cab. The power window/lock switch in the driver's door does not work at all. None of the other door switches work either, except for the power lock switch on the passenger door. Is it something as easy as replacing the switch in the driver's door, or do I have to start chasing wires? Previous to this problem, everything worked as it should.
Old Feb 5, 2014 | 04:39 PM
00DakDan's Avatar
00DakDan
Section Moderator
The power windows and door locks are separate systems. All the windows are fed from the drivers door, it's the master.
There is no fuse, it's protected by a circuit breaker in the junction box under the dash.
Odds are that the switch has failed, it's common. You can check for power to the switch. Pin #4, the tan wire, should be hot, it's the feed. Pin #7, yellow, should also be hot, it feeds the other doors. Also, check the ground, Pin #5, black. The ground itself is to the dash, just above where it pivots on the drivers side. There is also a jumper that connects to the truck body. Make sure they're intact.
Old Feb 5, 2014 | 09:42 PM
Tom A's Avatar
Tom A
Section Moderator
I just fixed a similar problem on a Durango a couple of weeks ago. It turned out the connector had come loose from the switch cluster inside the driver's door. I plugged it back in and it was good as new.
Old Feb 5, 2014 | 09:57 PM
magnethead's Avatar
magnethead
Mine is broken. It seats, but it can seat better.
Check that first.
Old Feb 6, 2014 | 08:38 AM
NorDakota's Avatar
NorDakota
Thanks for the info. I will pull off the door panel & check it out this weekend.
