Help need information on trans swap ASAP!
Old Feb 8, 2014 | 01:16 AM
BlackDakotaV8_4x4's Avatar
BlackDakotaV8_4x4
Default Help need information on trans swap ASAP!
I need to know if a 2001dodge ram 1500 nv 3500 4x4 with the 5.2 (318 will bolt up to a 1997 dodge dakota 5.2 (318) it's also a 4x4 but has auto transmission! Will they swap? I don't care for power connectors and stuff I'll so that later but will it bolt up and work? Need to know ASAP
Old Feb 8, 2014 | 10:43 AM
00DakDan's Avatar
00DakDan
Section Moderator
They should bolt up directly - but...
I've heard of some 5.2's that weren't drilled for the pilot bearing.
Old Feb 8, 2014 | 12:18 PM
BlackDakotaV8_4x4
How would I find out if mines drilled out or not before I go into buying the Manuel transmission?
Old Feb 8, 2014 | 01:06 PM
00DakDan's Avatar
00DakDan
Section Moderator
I get it, you have a '97 and want to make it a 5 speed using the '01 tranny.
You have to pull the transmission to verify the dimensions. Use an inside micrometer to measure. It may not be drilled to the correct diameter. Then take that measurement to your parts place and see if they have a bearing (or bushing) to fit.
Old Feb 8, 2014 | 01:31 PM
Brian in Tucson's Avatar
Brian in Tucson
According to Rockauto, manual transmissions were offered in 97. RockAuto list a bunch of Pilot bearings that they'll sell you. I think that you may need to pull the motor to find out, tho.
I can't imagine that the Big C didn't drill the crank for a pilot bearing--but hey, they have done some pretty unexplainable things, right?
Old Feb 8, 2014 | 06:43 PM
BlackDakotaV8_4x4
Exactly they were offering a nv3500 in the Dodge Dakota's with a 5.2 so I'm hoping that I don't have to take And have my crank worked on to fit a pilot bearing i'm hoping I can just pull my automatic transmission out and put the manual in the nv3500 in but I need the pedals and entire clutch and flywheel and longer driveshafts will I also have to move my trans crossmember?
Old Feb 9, 2014 | 06:06 PM
BlackDakotaV8_4x4
Ok I got the transmission and everything but the pedals and pilot bearing, but I'm needing to know if the pedals will work out of a 01 dodge ram will fit a 97 dakota, I think they will I'm just not sure
Old Feb 9, 2014 | 11:51 PM
BlackDakotaV8_4x4
Attachment 23183
New transmission
Attachment 23184
Clutch assembly and hydraulic clutch lines and parts
Attachment 23185
Hole was already there just needed to unbolt the plate and all
Attachment 23186
And I just set that here to see how it's going to look when I'm done with it all
