coilover conversion kit for 4wd???
Old Feb 12, 2014 | 10:45 PM
t.storey's Avatar
t.storey
Default coilover conversion kit for 4wd???
i doubt there is since the market for these trucks is so minimal but is there a coilover conversion kit so i can throw out those silly tbars???
Old Feb 13, 2014 | 12:02 AM
magnethead's Avatar
magnethead
Sure. It's called a SAS.
Old Feb 13, 2014 | 11:30 AM
98DAKAZ's Avatar
98DAKAZ
No one makes a thicker stiffer torsion bar for the Dakota or their is no room for a thicker bar is that the problem?
I remember on my Baja bug you had a number of stiffer bars to choose from I had them.
Old Feb 13, 2014 | 08:16 PM
dodgeramguy85's Avatar
dodgeramguy85
If your spending the time to ditch the bars might as well spend extra time and do a solid axle. After that you have unlimited lift possibilitys plus being way stronger.
Old Feb 13, 2014 | 08:42 PM
magnethead's Avatar
magnethead
see my reply.
Old Feb 13, 2014 | 10:28 PM
dodgeramguy85
Originally Posted by magnethead
see my reply.
Oh I know im +1 it and added a little more to it.
Old Feb 13, 2014 | 11:59 PM
toy4whatever's Avatar
toy4whatever
Question
I'm in the process of collecting parts for this. I have a set of 10" Radflo coilovers and i have the jigs built for a set of upper and lower control arms. I just need to order my uniball kits and bushing kits. Im thinking of using Ram 1500 axles for a little more width. For the ram axles to work I have to swap the outer shaft with the stock ones.
Old Feb 14, 2014 | 12:01 AM
magnethead's Avatar
magnethead
how are you planning to pass the axle shafts through the coil springs?
Old Feb 14, 2014 | 06:24 AM
RDuck's Avatar
RDuck
DOH!!
Lmao.
Springs would probably be on the upper arm. Just geussing.
Old Feb 14, 2014 | 10:16 AM
toy4whatever
The upper will be made from 1 1/2 DOM and will have more room for clearance. The coilovers will mount on the lower control arm. There is enough room between the steering and axle shaft.
