Trying to get clutch master to clear brake booster
Old Feb 15, 2014 | 12:24 AM
BlackDakotaV8_4x4's Avatar
BlackDakotaV8_4x4
Default Trying to get clutch master to clear brake booster
I need help or ideas to get my clutch master to clear my brake booster I'm taking my auto out and putting in a stick, are the brake boosters different from a auto to a stick? And FYI I got everything but the pedals out of a 01 dodge ram 1500
Old Feb 15, 2014 | 06:58 AM
98DAKAZ's Avatar
98DAKAZ
Did you follow the OEM instructions on installation because that matters.
I believe you must start by installing the refill tank first then back it is important to do it that way or the Ram 1500 parts don't work on a Dakota.
You can get the complete assembly from rockauto for $115 new its a one piece assembly not to be taken apart yes DO NOT take it apart.
Old Feb 15, 2014 | 09:30 AM
BlackDakotaV8_4x4
I'm going to match them at my job and all , I have a tight budget so I'm going to compare clutch masters at my job
Old Feb 15, 2014 | 09:37 AM
98DAKAZ's Avatar
98DAKAZ
When you get it don't cut the holding strap it snaps off on first use if you cut it before you install it my understanding is its almost impossible to get back in.
If you are thinking of piecing this stuff together don't do it as its very hard to impossible to get all the air out of the system after you open things up.
Many on this forum have tried and it never ends well $115 for the complete system is very cheap compared to many many and yes many hours trying to get the air out of the system and it still feels mushy.
Old Feb 15, 2014 | 01:21 PM
BlackDakotaV8_4x4
We'll I can get the slave and master from my work but I don't have the damn line between the too! Or I'd get them
Old Feb 15, 2014 | 01:46 PM
Tom A's Avatar
Tom A
Section Moderator
If you can post a picture of your booster and clutch master cylinder setup, I'll tell you if it looks like mine.
Old Feb 15, 2014 | 08:01 PM
BlackDakotaV8_4x4
Well when I got to work and had a chance I compared the parts, we'll I'm going to have to get the complete Assembly from rock auto . Com and use it because I can't get the connecting line that I would need if I just bought the items one by one....
Old Feb 15, 2014 | 08:30 PM
Tom A's Avatar
Tom A
Section Moderator
Well, that sucks. But some parts are just better bought new, anyway.
Old Feb 15, 2014 | 09:11 PM
BlackDakotaV8_4x4
until you has to pay for them, I'm a broke *** right now until not this Thursday but the next
