Need some help
Old Feb 22, 2014 | 10:18 PM
Compton09's Avatar
Compton09
Question Need some help
Hi I have been asking around and can't get a good answer from anybody. I would like to take a 5sp out of a 99 dodge Dakota with a 3.9 and put in my 2000 dodge Dakota. Will the 5sp bolt up and work???
Old Feb 23, 2014 | 09:20 AM
00DakDan's Avatar
00DakDan
Section Moderator
I moved your post into a new thread.
What engine do you have in the '00? Are both 2wd or 4wd?
Old Feb 23, 2014 | 10:51 AM
mtlrck4x4's Avatar
mtlrck4x4
it will bolt up but, you need to provide more information. the 99 3.9 is most likely an ax15. if your bolting to an existing 3.9 you should have nothing to worry about. if your bolting to a 3.9 a 4.7 bellhousing I believe is the same. you will need a flywheel and your computer will throw a tranny code. personaly I wouldn't mess with a 2000 97-99 where good years to swap parts around 2000 the wiring and computers changed. i figured out the hard way. if you are bolting to a v8 i suggest using a nv3500
Old Feb 23, 2014 | 12:03 PM
00DakDan's Avatar
00DakDan
Section Moderator
If your '00 is a 3.9 it will have the NV3500.
Old Feb 24, 2014 | 10:08 PM
Compton09's Avatar
Compton09
My 2000 has the 4.7 in it and its 4wd. I have the whole 99 Dakota to take what ever I need I would just like mine to be a 5sp
