Exhaust Leak Near Muffler
Old Mar 14, 2014 | 01:20 PM
sxrsil3nt's Avatar
sxrsil3nt
Default Exhaust Leak Near Muffler
Hey guys,
I've developed a small rust hole in the piping just before the muffler and I'm looking to repair it quick and dirty.
Has anyone had experience with exhaust tape or JB weld? I plan on drilling out the rust and trying some type of goop or tape. Not looking for something permanent. Just quick and dirty to pass an inspection.
Anyone have any experience with quick fixes?
Thanks
Old Mar 14, 2014 | 01:42 PM
Dodgevity's Avatar
Dodgevity
I'm an effin JB weld expert! LOL
Get one of those wire brushes you can attach to your drill and remove the rust from the the area real good. Spray brake cleaner to clean it. Mix the JB Weld epoxy stuff half and half, then apply to warm exhaust. Let it sit overnight and if it's real cold out, in a garage. If the hole is big enough where the JB weld it going to leak down into it, cover it with a small piece of metal cut from a tin can then make sure the JB Weld spreads beyond the edges of that.
Old Mar 14, 2014 | 02:50 PM
magnethead's Avatar
magnethead
I was going to suggest cutting a tin can and just hose-clamping it....
Old Mar 14, 2014 | 03:46 PM
Tom A's Avatar
Tom A
Section Moderator
Use a band clamp.
This one time, at band clamp...
Old Mar 14, 2014 | 04:24 PM
Dodgevity's Avatar
Dodgevity
I think they also sell a wrap that hardens. I'd use JB weld though. That will last.
Old Mar 14, 2014 | 04:36 PM
Robbadodge's Avatar
Robbadodge
Now that was funny!
Old Mar 14, 2014 | 04:43 PM
sxrsil3nt's Avatar
sxrsil3nt
Hahaha nice one Tom,
Would simply putting one of these clamps/tin can over the hole actually work? I thought that would just be a dead giveaway to fail me on the spot!
With JB weld or a tape I could throw some grease/dirt/oil over it to cover it lol!
Old Mar 14, 2014 | 05:42 PM
magnethead's Avatar
magnethead
you mean they actually look?
Far as i'm concerned, it covers the hole therefore these is no hole/leak.
Old Mar 14, 2014 | 07:18 PM
sxrsil3nt's Avatar
sxrsil3nt
Yeah they will do a visual inspection in Ontario.
Old Mar 14, 2014 | 07:20 PM
Tom A's Avatar
Tom A
Section Moderator
Same way I see it. If it's not leaking, what's there to fail you for? If you want to be really fancy, put a little bit of high-temp silicone around the hole before you put the clamp on. That way, you KNOW it won't leak. I'd consider that a permanent repair.
