Fuse for reading lights and radio out
There are no OEM inline fuses.
I found a set of generic Dakota wiring diagrams. They are pre-2000 but no year is shown so I hope it helps.
They show a 15 amp fuse that feeds both the radio and interior lights. It's fuse #12 in the junction block - that's the one just inside the drivers door.
Mine is a 1997 and I have posted a pic of the fuse block for your viewing. I cannot thank you enough for sticking with me on this.IMG_2591.jpg
Ok not that much diff
I never understood what light you were talking about the overhead console light or the Cab dome light on top of the rear window.
This may be were the real problem is.
Wiring problems are best handled by 00DakDan I'm not so good with wiring problems
Cab dome light http://www.ebay.com/itm/dodge-dakota-pickup-tan-overhead-over-head-interior-dome-light-/141016835308?pt=Motors_Car_Truck_Parts_Accessories&hash=item20d54224ec&vxp=mtr
Overhead console light http://www.ebay.com/itm/98-DODGE-DAKOTA-OVERHEAD-CONSOLE-WITH-DOME-LIGHTS-885112-/360802566768?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3ADodge%7CModel%3ADakota&hash=item5401824270&vxp=mtr
It is both the maps lights in the overhead consol and the overhead light in the back as well as the radio. As the pic I attached shows the fuse block is different in mine than the one you showed me. I have looked at the underhood breakers and nothing there seems to relate to interior lights or the radio. In answer to a previous post the radio is oem factory installed
Was a security system installed or other device by a company/store?
Or have you installed anything?
They may have installed it wrong tapped into the wrong wires.
Have you look under the dash to see if their is anything weird like wires hanging down lots of tape or wire splices?
My dome light would flicker on me at times so I looked under the dash to see a wire spliced wedged into the back of the fuse block upon touching it my dome light came back on.
why did this happen a shop installed my security system and messed some wires up.
You may have the same problem
