burnt out head light switch
Old Mar 31, 2014 | 10:20 PM
DurdyGP's Avatar
DurdyGP
Default burnt out head light switch
So what cause this again an how do I fix it from happening I dont what my truck to catch fire
File Type: jpg
Old Mar 31, 2014 | 10:22 PM
DurdyGP's Avatar
DurdyGP
Oh yeah its a 97 Dakota 2.5 2 wheel drive
Old Mar 31, 2014 | 10:48 PM
00DakDan's Avatar
00DakDan
Section Moderator
A bad connection can overheat. Are you running the OEM bulbs or something different?
Old Apr 1, 2014 | 06:44 AM
DurdyGP's Avatar
DurdyGP
OEM what head lights there just basic headlights
Old Apr 1, 2014 | 07:48 PM
00DakDan's Avatar
00DakDan
Section Moderator
OK, you have the stock bulbs (OEM).
It could just be a bad connection at the switch. Over the years they get hot, oxidize a bit, and that increases the resistance.
Check the connector. Make sure it's clean and tight when it goes onto the new switch.
Old Apr 1, 2014 | 11:04 PM
KillerKilgore's Avatar
KillerKilgore
Could also make sure the ground are getting good connection.
And as ACDC saids loose wires cause fires.
Old Apr 2, 2014 | 07:39 AM
DurdyGP's Avatar
DurdyGP
I posted a pic of the female side its melted I need to find a new harnesss or pig tail I guess its off to the wreckn yard I go
Old Apr 2, 2014 | 08:42 AM
01SilverCC's Avatar
01SilverCC
Anytime you have burned wires or connectors like that it means somewhere in that circuit you are drawing too much current. You can replace the connector plug and the switch but to permanently fix the problem you need to get a wiring diagram and find out what circuits or components are associated with the burned wires. Then troubleshoot the current draw problem from there. Use a good digital volt meter and an ammeter to isolate the problem. Otherwise you may have this same problem again soon.
Jimmy
