Trouble with throttle
Old Apr 11, 2014 | 07:09 PM
pizzadoe53's Avatar
pizzadoe53
Default Trouble with throttle
Hello I need some help with my 2000 Dodge Dakota 4x4 It has a 4.7 trouble with the throttle , as I drive 50 to 60 mph the IACV makes the idle go from 1800 rpm to 2300 rpm then back down, I have change the IACV with no luck ,Starts fine idle fines, Could use some help with this
Thank you
Old Apr 11, 2014 | 07:29 PM
Moving this to the second gen dakota section. That's a whole different animal than what we are used to dealing with.
Old Apr 11, 2014 | 07:34 PM
00DakDan's Avatar
00DakDan
Section Moderator
What do you mean the idle goes from 1800 to 2300 rpm as you're driving? The engine shouldn't be idling then.
It sounds more like a transmission problem, going into/out of overdrive.
Do you have any codes?
Old Apr 12, 2014 | 11:01 AM
pizzadoe53's Avatar
pizzadoe53
I should not have said idle it's when I am driving 50 to 60mph , there is no code showing
Old Apr 12, 2014 | 12:41 PM
00DakDan's Avatar
00DakDan
Section Moderator
Still sounds like a transmission problem.
Old Apr 12, 2014 | 03:16 PM
sxrsil3nt's Avatar
sxrsil3nt
I agree with Dan.. sounds like a tranny problem.
Is it like this?
