Fiberglass Question
Old May 14, 2014 | 10:02 PM
01dak3.9's Avatar
01dak3.9
Default Fiberglass Question
I am getting ready to build my sub box and I am going to fiberglass the bottom on each side of the trans tunnel. Is a pint of resin enough or should I get more? This is what I'm looking at.
Amazon.com: Bondo 431 Fiberglass Resin Jelly Kit - Pint Can: Automotive Amazon.com: Bondo 431 Fiberglass Resin Jelly Kit - Pint Can: Automotive
Old May 15, 2014 | 02:05 PM
TheNewbie's Avatar
TheNewbie
That's a kind of hard question to answer. What is the square footage you are working with here? What kind of fiberglass materiat are you working with? What thickness/weight material?
I'm assuming you mean you're building a custom fiberglass subwoofer enclosure that will mold to the shape of the floor of your truck?
Old May 15, 2014 | 04:39 PM
01dak3.9's Avatar
01dak3.9
I'm not sure on square footage It is about the size of the back seats in a club cab and only on the sides of the hump. And yes.
Old May 16, 2014 | 12:25 PM
TheNewbie's Avatar
TheNewbie
What kind of material are you using? If you're just doing the floor section and only going one layer thick then yes one pint would be enough. If you go thicker you may or may not use a second one.
Old May 16, 2014 | 12:26 PM
TheNewbie's Avatar
TheNewbie
I see now that the link you put up is for a kit that comes with fiberglass cloth. That stuff shouldn't soak up as much resin as the matt so you should be good to go. But it doesn't say how much cloth it comes with.
Old May 16, 2014 | 03:55 PM
01dak3.9's Avatar
01dak3.9
will silicone spray work as mold release or would something like candle wax be better?
Old May 16, 2014 | 05:05 PM
TheNewbie's Avatar
TheNewbie
Honesty that's a bit above my pay grade. Maybe someone else can chime in.
My only real experience with fiberglass has been in redneck boat building and getting it to stick to stuff not to release from a mold.
I have absolutely no experience with making DIY sub boxes, but if you want to mold it to the floor I would think that laying down a layer of plastic or something and then building your layers on top of that would be the way to go. Again, I'm just thinking out loud here so make sure to do your research. I don't even know if poly resin is safe to use on plastic or if it might melt through some types of plastic.
