Transmission Question
Old May 18, 2014 | 02:37 PM
Tom A's Avatar
Tom A
Section Moderator
I believe the 5.9 is externally balanced and requires a different flywheel than the 5.2 for this reason. Also, as I understand it, the NV4500 won't fit without sheet metal modifications or a body lift. I think the shifter also comes through the floor in a different spot from the NV3500, which makes it a little more challenging.
I would just go with an NV3500 since it bolts right up and it's plenty strong. Mine has almost 200,000 miles on it and I regularly tow 7,000 pounds with it.
Old May 19, 2014 | 12:21 PM
BlackDakotaV8_4x4's Avatar
BlackDakotaV8_4x4
Originally Posted by Tom A
I believe the 5.9 is externally balanced and requires a different flywheel than the 5.2 for this reason. Also, as I understand it, the NV4500 won't fit without sheet metal modifications or a body lift. I think the shifter also comes through the floor in a different spot from the NV3500, which makes it a little more challenging. I would just go with an NV3500 since it bolts right up and it's plenty strong. Mine has almost 200,000 miles on it and I regularly tow 7,000 pounds with it.
oh, I didn't know that, why are they not internally balanced?
Old May 19, 2014 | 01:06 PM
00DakDan's Avatar
00DakDan
Section Moderator
It was a design consideration to keep costs down. They didn't want to modify the block for the longer stroke.
Old May 21, 2014 | 06:20 PM
krusinskimax's Avatar
krusinskimax
So for a donor truck I can you rams and Dakotas. Could you use a Durango? or is that a totally different set up. I am just looking for a donor to use
Old May 21, 2014 | 06:25 PM
Tom A's Avatar
Tom A
Section Moderator
I've never seen a manual Durango. Is there such a thing?
Old May 21, 2014 | 06:37 PM
krusinskimax
I am not sure, I figured they would have made a manual Durango. maybe not
Old May 21, 2014 | 06:39 PM
krusinskimax
Well I looked it up seems like dodge didn't make a manual Durango in the states
Old May 24, 2014 | 12:41 AM
krusinskimax
I may have found a donor truck. It is a 1995 ram 5.2l, now my question is how would I tune the pcm for my 5.9 Would it be easy to reprogram or would I have to take it to a dealership, I already have an sct tuner by hemifever
Old May 27, 2014 | 11:34 AM
TheNewbie's Avatar
TheNewbie
An sct tuner and custom tune by hemifever would have been my first thought. I'd ask him first...
Old May 29, 2014 | 07:56 AM
krusinskimax
He said he could tune my pcm for a manual.
