new clutch, no start
Hi and welcome to the forum. I moved your post into a new thread.
What engine do you have?
There is a crankshaft position sensor that reads off the flywheel (notches). Is it in place and the wires connected? Was the sensor damaged or the wire pinched between the engine/bellhousing? Back of engine, passenger side top.
I want to thank everybody for the helpful information on my 1998 Dodge Dakota with the starting problem. Forgive me for not including the engine #. My buddy and I were in a down mood when I sent my request. It was indeed the crank sensor. From what we can see, the yoke was already cracked and the sensor would have to be replaced anyway. The real problem was we weren't up on the Dodge trucks in that regard. The sensor came right out when removing the transmission, which neither of us saw, and as well, neither of us had seen this sensor going into the bell housing in the first place. So, many thanks for the info and I hope we can work something out again.
R.G. NELSON
R.G. NELSON
