stubborn coolant leak
Old Jul 5, 2014 | 11:42 AM
98beater's Avatar
98beater
Default stubborn coolant leak
Hey guys. I have a 99 3.9 Dakota and have a stubborn coolant leak. I replaced the water pump and gasket and it leaked out of the bottom of the pump, right on top of the balancer. So I replaced it again, and its still leaking from the same spot! I don't know where to look, if there's a step I missed somewhere or something I don't know, just hoping you guys can give me a couple ideas where to start.
Old Jul 5, 2014 | 11:46 AM
01SilverCC's Avatar
01SilverCC
First thing to do would be rent a coolant system pressure test kit at the parts store, it will help show the source of the leak. Did you replace the bypass hose when you did the water pump? If not it may be leaking too. Be sure to use all new screw type hose clamps. There is a special Permatex sealant for water pumps and thermostats, it works great and sets up quickly. I have found it to be the best sealant for water pumps.
Jimmy
Old Jul 5, 2014 | 01:47 PM
98DAKAZ's Avatar
98DAKAZ
It looks like the pump is soft aluminum so if you crank down on the mounting bolts too much you can warp the pump housing.
Old Jul 5, 2014 | 08:35 PM
archemedes74's Avatar
archemedes74
are you getting reman pumps? I've seen them be warped in the box (not one of the checks most rebuilders check for some reason) I had one for a ford that every one on the shelf at 4 different stores (including napa and car quest) were all warped (all used same rebuilder in China) part of the reason I only use new
Old Jul 5, 2014 | 10:05 PM
98beater's Avatar
98beater
I replaced the bypass hose when I did the plenum gasket a few months ago. And I used the sealer you mentioned when I did it a second time.
I'm gonna pull it apart (again ugh....) and check the pump with a straight edge. Thanks for the ideas guys.
Old Jul 5, 2014 | 10:35 PM
01SilverCC's Avatar
01SilverCC
I bought my water pump at Auto Zone. I have had it on my truck now for about 3 years, and have had no problems at all with it. It was a new pump, not reman and it was made in the USA too.
Jimmy
Old Jul 5, 2014 | 11:35 PM
archemedes74
Jimmy
and probably only a couple bucks more than a reman
Old Jul 6, 2014 | 02:06 AM
98DAKAZ's Avatar
98DAKAZ
Yes get new
From service manual
INSTALLATION
(1) Clean gasket mating surfaces.
(2) Using a new gasket, install water pump to engine as follows:
Guide water pump nipple into bypass hose as pump is being installed. Install water pump bolts. Tighten water pump mounting bolts to 40 N·m (30 ft. lbs.) torque.
