1999 dakota no speedo and abs light
Hello everyone, just joined. I've looked over many threads and can't seem to find the fix to my problem. The problem being that my speedometer doesnt work and the abs light is always on. I've changed out the rear abs sensor and it made no difference. it's 4 wheel abs, 4x4 3.9l v6. The wires seem to be in decent condition, though there is some movement at the input to the abs sensor. Any ideas? Thanks. UPDATE: turns out the cab was unplugged by the previous owner because the abs pump was broken. Looks like I found my fix.
I'm glad you found your problem and it was a quick fix. However, I just replaced my rear abs speed sensor. The abs and brake lights on the dash went away, but my speedometer is still not working. The wire connection dose not seem to make a tight seal and I am able to remove it again easily. I'm not sure if I got the right sensor but part of the problem (lights on the dash) went away. Anyone have any ideas?
