Transmission failing to disengage
Old Aug 22, 2014 | 09:46 AM
Blacknights's Avatar
Blacknights
Default Transmission failing to disengage
Hey guys,
So I can't find the thread from a while back so I've got to ask the question again (sorry).
Necessary info: 2001 4x4 545RFE (auto) transmission
So the issue is, when I apply the brakes regardless of force (light, hard). The transmission some times fails to disengage automatically and will "wind up" persay. It always does in the end but it isn't nearly as responsive as it should be. I think someone had say it was an issue with the crankshaft positioning sensor, and it needed to be replaced. Can anyone help me out?
Old Aug 23, 2014 | 01:51 AM
olsarge's Avatar
olsarge
Sounds like you might be low on trans fluid and the TC is trying to stay in lockup mode.
Old Aug 23, 2014 | 11:17 AM
Blacknights
The tranny fluid is clean and at just about perfect on the stick when both hot and cold. The fluid was flushed & replaced about 10,000 miles ago.
Old Aug 23, 2014 | 12:38 PM
sxrsil3nt's Avatar
sxrsil3nt
When you say "wind up" do you mean you come to a stop and the transmission get's stuck in a higher gear? Could be your governor pressure solenoid - I've had the same issue in my Dakota.
This was in a 42RE however, the 545RFE might be a little different.
Old Aug 23, 2014 | 01:23 PM
magnethead's Avatar
magnethead
The RFE is all electronics. there has to be a solenoid or sensor sticking.
Old Aug 23, 2014 | 02:46 PM
tspeed109's Avatar
tspeed109
Default transmission speed sensors
Mine was doing the same thing it was a transmission speed sensor. There are 2 on the side of trans that look like crank sensors. One does the shift and the other does speedo.
Old Aug 24, 2014 | 12:30 AM
Blacknights
I will look into the speed sensor, I haven't gotten it out on the highway to test it at higher speeds recently (I just got the truck back). But I'm starting to think my abs system is acting up or my rotors are more warped (leaning towards rotors). Because it is braking weird now; this is a newer development.
Old Aug 24, 2014 | 02:23 AM
cber's Avatar
cber
Well the torque converter is what "disengages" an automatic transmission when you apply the brakes, it's why you can creep so much easier in an automatic as opposed to a manual. Without burning out your clutch, a manual is either on or off, and you will always move at idling speed at the very least (without bogging your engine down) when in gear. The torque converter takes the place of the clutch pad and pressure plate in an automatic, and is operated by fluid inside it. In some torque converters there is a clutch pad inside it that will engage whenever you are cruising steadily at a particular speed, so it could be that not releasing, or it could be a million other things.
Maybe take a video so we can see what you mean by "winding up".
Old Aug 24, 2014 | 08:58 AM
Blacknights
I'll try to, just right now it is very random. Example, drove the truck 4 times yesterday and not one did it happen. Picked it up from the shop 2 days before that it happened twice on the drive home (I think).
