Differential fluid change
Old Aug 25, 2014 | 07:54 PM
  #31
cber's Avatar
cber
Originally Posted by 00DakDan
The point is Cber that the transmission and differential take VERY different fluids.
If the differential has the additive, even if you don't need it, it won't hurt it. But, put the wrong oil in your transmission and in short order, you'll be rebuilding it.
Trackin'. I'll go ahead and just drain it and pick up some fresh fluid, just to be safe, as soon as I get it back on the ground here in about an hour. I just got paid by Googitube so I've got the cash, and it doesn't take 5 minutes.
Old Aug 25, 2014 | 08:18 PM
  #32
cber's Avatar
cber
Just called Advance and she looked up my order of transmission fluid and it was described in the computer as Valvoline 75W-90 "Synpower" full synthetic oil. I'm gonna run down to the store and look up that item number and see if it's the one with the limited slip label on it.
Old Aug 25, 2014 | 08:32 PM
  #33
Dodgevity's Avatar
Dodgevity
This is how it is described on Valvoline's website... Looks like it includes friction mod for LSD.
SynPower® Full Synthetic Gear Oil
Formulated for ultimate protection and performance
  • Contains additives to assist in protecting gear teeth
  • Maintains excellent low temperature fluid protection down to -50°F (-46°C)
  • Provides outstanding thermal stability for cleanliness and longer service life
  • Contains special additives to reduce chattering in limited-slip differentials
  • Recommended for (conventional and limited slip) manual transmissions where an API GL-5 or MT-1 fluid is specified
  • Protects parts from rust and corrosion
  • Compatible with conventional gear lubricants
Old Aug 25, 2014 | 08:57 PM
  #34
Tom A's Avatar
Tom A
Section Moderator
You're missing the point. The transmission does NOT take "gear oil" of any kind, limited-slip or not. It takes special manual transmission lubricant and there are only a few brands that are approved. Pennzoil, Royal Purple, Red Line, and Mopar are the only ones I'm aware of and even then, it MUST say "syncromesh" or something like that. If you're not sure, get it from the Dodge dealer.
Those fluids are NOT specified for the NV3500.
Old Aug 25, 2014 | 09:04 PM
  #35
cber's Avatar
cber
Went to Advance and every single bottle of 75W-90 there has friction modifier. Valvoline, Royal Purple, Mobile 1, Lucas, even the Autocraft (store brand) all said, "For use in manual transmissions, hypoid differentials, contains friction modifier, etc."
I'll double check Car Quest tomorrow just out of curiosity, but I'm guessing there's no such thing as 75W-90 without friction modifier any more.
Also I checked just to be sure, mine has the AX-15 transmission (3.9L engine).
We DO have a brand new Chrysler dealer that opened up, may give them a call and check on this whole issue tomorrow as well.
Old Aug 25, 2014 | 09:15 PM
  #36
Dodgevity's Avatar
Dodgevity
Available at Advance. I think this is what you need.
http://shop.advanceautoparts.com/p/p...il+synchromesh
Pennzoil Synchromesh Manual Transmission Fluid is designed for certain manual transaxles and transmissions used by GM and Chrysler. Provides excellent oxidation stability, low-temperature performance and synchronizer performance.
Old Aug 25, 2014 | 09:58 PM
  #37
00DakDan's Avatar
00DakDan
Section Moderator
In the AX-15 you can use 75w-90 - BUT NOT a GL-5 oil.
You can use 75w-90 GL-3 gear oil. GL-5 IS NOT COMPATIBLE.
Good luck on finding a GL-3 gear oil nowadays. Syncromesh fluid is fine.
There's more to an oil than it's weight. Don't trust the guys at the parts store. All they know is what the computer tells them.
  #38
Tom A's Avatar
Tom A
Section Moderator
I'm not positive what the AX-15 takes, but I seem to remember from my days of owning a Jeep that it can use gear oil, as long as it's not GL-5. I would still call the dealer, though.
*EDIT*
Dan beat me to it.
Old Aug 26, 2014 | 12:18 AM
  #39
98DAKAZ's Avatar
98DAKAZ
From allpar
http://www.allpar.com/mopar/transmissions/NV3500.html
The AX-15 uses 75w-90 GL-4 or Redline MT-90 If I remember correct they say that Mobile-1 75w-90 is bad for the AX-15 as it eats the syncros but its been in my AX-15 8 years with no problem.
Bad info is everywhere always do your own research and double check
Old Aug 26, 2014 | 09:37 AM
  #40
cber's Avatar
cber
Found 3 bottles of this today. Haven't put it in yet. The MOPAR part number listed on the bottle is different than the one listed in the instruction manual. Is this the one you were talking about?
