Steering/ Braking Riddle...
Old Sep 22, 2014 | 09:55 PM
kenwill92's Avatar
kenwill92
Default Steering/ Braking Riddle...
When i drive straight on a road and hit a bump, the steering wheel will turn left. A lot left. But the truck doesn't turn, only the wheel. And it doesnt matter which tire i hit the bump with. When i brake hard enough to stop the truck, the steering wheel will correct itself. Again, without turning the whole truck. Any advice will be appreciated because im lost.
Old Sep 22, 2014 | 10:06 PM
magnethead's Avatar
magnethead
Sounds to me like an interference connection between the steering wheel and the rack and/or the Power Steering system. Does it turn ok with the truck stopped? If the truck itself is not turning and the wheel is, you need to stop driving it because you are losing wheel to road connection. Almost sounds to me like you have a broken or soon to be broken intermediate shaft or rack pinion gear, like a cotter pin has backed out or an edge has rounded off and is allowing the wheel to turn disconnect from the rack....possibly by and edge. Is there an exact and replicable amount that the wheel moves?
Old Sep 23, 2014 | 08:45 PM
Tom A's Avatar
Tom A
Section Moderator
What happens if you turn the engine off, but leave the key on (steering unlocked) and try to steer? Does the steering wheel move but not the wheels? Or does it steer ok but just hard to turn (as you would expect)?
Old Sep 25, 2014 | 10:11 AM
kenwill92's Avatar
kenwill92
Its just hard to turn like normal and theres no float. It needs an alignment crazy bad though
Old Sep 25, 2014 | 10:20 AM
kenwill92's Avatar
kenwill92
Also, when it is in the middle of turning left by itself, if i steer right the truck will turn right
Old Sep 25, 2014 | 10:25 AM
kenwill92's Avatar
kenwill92
Yes its always the same amount unless i hit little bumps, then it turns little by little but it ways stops at the far left limit that it does if i hit a normal bump. Little bumps being a decent sized crack and normal being potholes, speed bums, etc.
Old Sep 25, 2014 | 05:29 PM
magnethead's Avatar
magnethead
1) get it on an alignment rack STAT
2) Have them re-center the wheel and check the power steering system
Old Sep 26, 2014 | 12:06 PM
kenwill92's Avatar
kenwill92
Will do. Its not being driven now its not in my name yet but as soon as its registered ill take it down and get it fixed. Thanks guys
