power steering fluid
Old Sep 23, 2014 | 06:12 PM
indiglofish61's Avatar
indiglofish61
Question power steering fluid
I read on my 2000 dodge Dakota slt 3.9L V6 manuel to use only mopar power steering fluid, then I went on line and lots said it was ok to use AFT+4 transmission fluid, ? is, which recommendation should I listen too. Anyone?
Old Sep 23, 2014 | 07:19 PM
00DakDan's Avatar
00DakDan
Section Moderator
Do not use ATF+4 which is MS9602 fluid.
There is a TSB out on the power steering fluid. TSB 19-005-03. With it comes LOTS of confusion. It is specific enough to state that "MS9602 should not be mixed or used as a “topping off” fluid on systems requiring MS5931"
Use MS5931 fluid - power steering fluid. That's what your truck came with OEM and is the approved "service fluid."
Old Sep 23, 2014 | 07:58 PM
indiglofish61
oodakdan, The manuel on mine says P/N 04883077 fluid, but I was wondering cause the guy on line said to drain the steering fluid then flush it out with some of the AFT+4 then fill it with AFT +4, and it should be all right. I am having trouble finding the P/N 04883077 fluid. So I am stuck right now, lol!
Old Sep 23, 2014 | 09:17 PM
00DakDan's Avatar
00DakDan
Section Moderator
It doesn't have to be Mopar fluid but must say meets Mopar MS5931 spec.
http://www.autozone.com/autozone/acc...er=828028_0_0_
http://shop.advanceautoparts.com/p/v...2241/7120648-P
http://www.valvoline.com/products/br...ering-fluid/29
Lots of people do use ATF+4 but that is not how I read the TSB. It says "some past models" and does not list the 1994-2001 Dakota. You won't go wrong with the MS5931.
Old Sep 24, 2014 | 09:00 AM
indiglofish61
ok 00DANDAK, thanks for the links, I will use the power steering fluid, it said too on the manel not to use tansmission fluid, so I was wondering about that, thanks again!
Old Sep 24, 2014 | 02:23 PM
sxrsil3nt's Avatar
sxrsil3nt
My manual says ATF4 can be used and that's exactly what I'm using right now.
No problems for over a year.
Old Sep 24, 2014 | 02:38 PM
98DAKAZ's Avatar
98DAKAZ
Wink
Royal Purple Synthetic Power Steering Fluid works great in my Dak
LINK LINK
I used the Autozone stuff but it got dark fast so I dumped it
Old Sep 24, 2014 | 02:45 PM
98DAKAZ's Avatar
98DAKAZ
Talking
http://www.royalpurpleconsumer.com/p...generalbranded
