What performance mod should i do?
Old Sep 27, 2014 | 02:39 AM
ksherek10's Avatar
ksherek10
Default What performance mod should i do?
This is my first time attempting to do a performance mod to my truck and i dont know what i should do. I have an 01 dakota sport v6. i was thinking maybe a cold air intake or something like that. Just needing some suggestions from people who might have done this before.
Thanks
Old Sep 27, 2014 | 08:25 AM
magnethead's Avatar
magnethead
clutch fan delete, lincoln/taurus E fan, harland rockers from john mercedes, SCT from hemifever@aol.com, 4.10 gears, CAI, modified throttle body (DIY or FastMan)
Old Sep 27, 2014 | 04:23 PM
moe7404's Avatar
moe7404
i have a 01 dak V6 stock. i use a MR. gasker 720-1487 air cleaner. 9" dia - 2 4/3 tall-5 1/8 neck. $20.xx dollars. bolt on. i dont like cold air systems they let to much dirt and leaves ect in to the system.
Old Sep 29, 2014 | 08:21 PM
dodgeramguy85's Avatar
dodgeramguy85
Depends what you are looking from your v6. Its not gonna be a lot of power and some say the money you were gonna spend on it would be better saved for a v8 swap. Things to get a little bit more pep are cai, exhaust, throttle body and tuner. Deleting the clutch fan and replacing with a Efan will give you a bit better throttle response and a few hp not really enough to notice tho. After that you are gonna have to get into motor work.
Old Sep 30, 2014 | 01:15 PM
jondakotaguy's Avatar
jondakotaguy
Youll notice when the truck is hot and temps are up when normally the Clutch is dragging your power down.. :P
and yeah thumbs up at the DIY Throttle body mod.. get the V8 TB and cut the air horns off.. will help when at highwya speed or when you go WOT> at least on my V8
Old Oct 1, 2014 | 01:30 PM
TheNewbie's Avatar
TheNewbie
What's your budget? We could throw a parts list at you all day long that would make you drool about everything you could do to your truck. But do you have a dollar figure in mind?
Everything above is spot on though. Intake and tuner would probably be on the top of the list. Upgraded rockers or deeper axle gearing would be next, not easy mods though.
Old Oct 1, 2014 | 02:15 PM
98DAKAZ's Avatar
98DAKAZ
If your not so good at modifying or moding parts like a throttle body you can buy pre modified Throttle Bodies some are even bored to a larger size but they can be expensive check this place out https://www.thefastman.com/throttle_bodies.php
Old Oct 1, 2014 | 02:17 PM
magnethead's Avatar
magnethead
John's harland rockers are actually pretty easy. they're direct bolt-on and only take about an hour. Harder part is getting the valve covers off and not letting crap fall in.
Old Oct 3, 2014 | 09:57 AM
jondakotaguy
@ magnethead... hope your missing the ebola up there man.
@ ksherek10 on the e-fan mod i have the 2011-2014 liberty fan assembly if you feel like doing the liberty fan mod.
Excuse me while i shamefully plug my own FS thread lol
https://dodgeforum.com/forum/user-cl...n-project.html
