'97 Dodge P/U Won't start
Old 10-06-2014, 01:19 AM
magnethead's Avatar
magnethead
magnethead is offline
should be able to hear it prime the fuel rail to 45ish PSI then shut off, with the engine off. Should also be fuel behind that schrader test port.
That said, 1.6A sounds on the low side. I'd be expecting 5-8 amps.
Old 10-11-2014, 07:58 AM
raybbr's Avatar
raybbr
raybbr is offline
Started cutting the hole in the bed. Will get to it when fall baseball or the weather cooperates.
Old 10-12-2014, 08:07 PM
raybbr's Avatar
raybbr
raybbr is offline
Pulled the pump out. It runs on the bench. If I put my finger over the output port I barely feel any air. Ordered a new one through Amazon.
Old 11-01-2014, 02:30 PM
raybbr's Avatar
raybbr
raybbr is offline
Default New pump
I've installed the new pump and I get a trickle of gas.
See Video at http://vid87.photobucket.com/albums/...ps6gp3ptob.mp4
Sorry it's sideways but I've yet to find a way to straighten it out using the recoding software I have.
It's just a trickle. Certainly not enough to get the line pressurized. That line is right on the output of the filter on top of the pump unit.
I'm guessing I've got a bad connection somewhere. I plan to hook up my 12 charger directly to the pump and will see what I get.
Ray
Old 11-01-2014, 03:03 PM
00DakDan's Avatar
00DakDan
00DakDan is offline
Section Moderator
Dodge Forum Moderator
Check the fuel pump relay.
Quick Reply: '97 Dodge P/U Won't start
