99 project starting. need help
Old Oct 6, 2014 | 02:53 PM
jrox44's Avatar
jrox44
Well that solves that haha. Everything else will be alright thou? The 01 motor to my tranny . And all the body parts pretty much I need. Bed, front quarters, doors, bumper , and hood
Old Oct 6, 2014 | 03:38 PM
00DakDan's Avatar
00DakDan
Section Moderator
The body parts are the same. Electrical connections may vary a bit so just use the '99 stuff.
Old Oct 6, 2014 | 04:30 PM
jrox44's Avatar
jrox44
Okay thank you a ton. Any sensor that don't just plug into my ECM just pull the sensor from the 99 motor and I should be alright. But I can't imagine too many being different. I'm gonna drop some serious money In to the old 99 motor on a rebuild kit. Currently haven't found any stroker kits or high compression kits.
Old Oct 6, 2014 | 05:40 PM
00DakDan's Avatar
00DakDan
Section Moderator
Just use the '99 sensors and you're fine.
Old Oct 6, 2014 | 06:43 PM
magnethead's Avatar
magnethead
alot more is different than you think, electrically.
I highly suggest getting the FSM download, a good haynes book for both years, a pin crimper, and a pin extractor.
Old Oct 6, 2014 | 07:15 PM
00DakDan's Avatar
00DakDan
Section Moderator
On the engine, use the '99 harness and sensors and you shouldn't have a problem. Don't try to use the '01 stuff.
