starting issues
Old Oct 11, 2014 | 01:51 PM
scottdd's Avatar
scottdd
Default starting issues
2002 4.7 4x4
cold truck starts just fine, after it warms up and you make a quick stop at a gas station, go to restart, it will start very rough, then dies, out, has hard time restarting, after about 5-10 tries she finally gets going very rough then evens out. Kinda sounds like it loading up on fuel. Any tips/pointers?
Old Oct 11, 2014 | 02:53 PM
00DakDan's Avatar
00DakDan
Section Moderator
Welcome to the forum!
Put a fuel pressure gauge on it, you can rent/borrow one. When you shut it down watch the pressure.
You may have a leaky injector "flooding" a cylinder.
Old Oct 12, 2014 | 11:04 AM
scottdd's Avatar
scottdd
ok checked the pressure this am, book says its supposed to be between 48-54, Running i was only getting 25. killed it to see if it leaked down for a few min it dropped to 22.
Old Oct 12, 2014 | 03:21 PM
00DakDan's Avatar
00DakDan
Section Moderator
25? Something is wrong. It should be about 49.
Did you try your start, heat up, shutdown, restart cycle with the gauge on it? I'm curious as to what it is hot.
Sounds like you'll be changing a pump.
Old Oct 17, 2014 | 03:56 PM
scottdd's Avatar
scottdd
yes i drove it to advance to use the fuel pressure gauge, so it was hot when i got there.
Now in addition the fuel gauge is not reading. Wondering if it could be the fuel pump/regulator in the tank?
Old Oct 17, 2014 | 04:23 PM
00DakDan's Avatar
00DakDan
Section Moderator
Fuel gauge not reading? First, try another. Then prepare to change the pump.
Old Oct 19, 2014 | 12:06 AM
magnethead's Avatar
magnethead
he meant fuel level gauge.
Sounds to me like a sloppy connection.
