Newbie needs some help
Old Nov 11, 2014 | 01:11 PM
00DakDan's Avatar
00DakDan
Section Moderator
Here's another:
SLIPS IN LOW GEAR ONLY, BUT NOT IN MANUAL 1 POSITION
Overrunning Clutch Faulty. Replace overrunning clutch
All I can say is do not throw parts at it or it can get expensive fast. You can check the line pressures and do some testing. Not everything throws a code as you found and not all scanners can't detect transmission codes.
