am fixing to replace the VC gaskets, ordered a set of good felpro rubber, just wondering for those that have used them did you use the factory torque spec of 80in/lbs ?? or just snug them good ?? was wondering since they are a different material than oem
my 01 dak book says for a V6 3.9 head cover, I,E, valve cover. 95 in lbs. sounds a bit tight to me. but i have always done 10 ft lb. i use a 1/4 drive and choke it between index and middle finger and and make it a little more than snug.
they are the blue rubber over steel type, just got here today from rockauto,
ill snug them good and keep a eye on them, gonna do these when i do the plenum kit , dang holidays are slipping up on me and garage time is gonna get scarce for a time.
Yes the Felpro Blue's are what we run on the oil pan and valve covers. We run Felpro Black's with the blue silicone built in for the intake gaskets, and we use regular stock style exhaust gaskets sprayed in copper-coat so we can keep re-using them. Head gaskets are Cometic MLS sprayed in copper coat for re-usability.
i almost ordered different intake gasket, but figured id use the ones with the Hughes kit, they should be more than sufficient for this round. once i get this all done and the trucks back on the road then hopefully it will be time to get with sean and get the tuner ordered.
