Broken CV Joint someone HELP
Old Dec 2, 2014 | 07:27 PM
00DakDan's Avatar
00DakDan
Section Moderator
Do you have 4 wheel ABS? If so there is a tone ring on the front. I'm not sure exactly where on an '03 however. In my '00 it is in the front bearing but it does change with different years.
Old Dec 2, 2014 | 07:34 PM
jmasselli22's Avatar
jmasselli22
how do i know if i have 4 wheel ABS or not?
Old Dec 2, 2014 | 08:26 PM
Tom A's Avatar
Tom A
Section Moderator
Originally Posted by jmasselli22
i spoke to the receptionist not the actual mechanic and i am a bit confused on whether she understands that i dont need a whole new axle just half; unless both sides are broke.
I think part of the confusion is that what people here are properly calling a halfshaft is more commonly referred to as a CV axle assembly. So you actually have two front axles if you think of it that way.
I just checked my price on an aftermarket axle assembly (I work in a shop and buy at wholesale) and it's $43.48, so even if it costs you twice that much, it's worth doing the work yourself. If you've never done one before and you have to follow the instructions step-by-step, I still can't imagine it taking you more than a couple of hours. If you do them regularly, and use air tools, it's probably more like 30-45 minutes.
Old Dec 2, 2014 | 08:48 PM
00DakDan's Avatar
00DakDan
Section Moderator
Get a build sheet:
Here : https://dodgeforum.com/forum/2nd-gen...ur-dakota.html
Old Dec 2, 2014 | 10:43 PM
jmasselli22
So if the part says front right and front left it is both sides of the CV axle. if it says just CV axle assembly it is just one side that is included. That makes more sense thanks. although i may have to go to the mechanic because i don't think i have the proper tools to do this work in my garage. are there any specialty tools you would need?
Old Dec 2, 2014 | 11:18 PM
00DakDan's Avatar
00DakDan
Section Moderator
It can be done with basic hand tools. Basically you jack the truck, remove the caliper/rotor, remove the hub, use some pry bars to disengage the old axle and pop it out. Then the new shaft goes in, you reinstall the hub/rotor/caliper put the wheel on and your done. Sometimes getting the old hub off can be a chore, due to rust.
A "CV axle assembly" is just one side. It should specify which side it goes on.
The FSM calls it a half-shaft. Lots of different names for the same part.
You can download a FSM for your truck, here: https://dodgeforum.com/forum/2nd-gen...-download.html
We don't have the '03 version but the '01 is almost identical. You'll get an idea of how to change the parts anyways.
Old Dec 3, 2014 | 08:44 AM
sxrsil3nt's Avatar
sxrsil3nt
Dan and Tom have pretty much nailed it on the head but you have 2 CV axles aka 2 half shafts.
One connecting the passenger side wheel to the dif housing, one connecting the driver side wheel to the dif housing.
Like Dan said remove the wheel, caliper, rotor, hub and possibly the tie rod just for more room if needed and pry out the whole CV axle. It will most likely be a pain to remove but it does pull straight out... Expect the splines to be a little rusty near the axle seal.
Oh and of course if the new axle doesn't come with a new seal, replace it while you're there.
