Broken CV Joint someone HELP
Old Dec 2, 2014 | 04:02 PM
jmasselli22's Avatar
jmasselli22
Default Broken CV Joint someone HELP
I broke a CV joint on my 03 dakota slt 4x4. can i get a new joint and replace it or do i have to get a whole new CV axle???
Old Dec 2, 2014 | 04:24 PM
sxrsil3nt's Avatar
sxrsil3nt
Replace the axle - I think they are $80 or so on Rockauto.
Old Dec 2, 2014 | 04:46 PM
jmasselli22
do i NEED a new axle or is it possible to just replace the joint?
Old Dec 2, 2014 | 05:00 PM
jmasselli22
also, do i need a whole new CV axle, or a new CV intermediate half shaft for the side that the joint is broken? do i need a CV drive axle with shallow snap ring? and knowledge is appreciated
Old Dec 2, 2014 | 06:30 PM
00DakDan's Avatar
00DakDan
Section Moderator
You only "need" to replace the half-shaft on the side that broke, they are not connected to each other. The shallow/deep snap ring does not apply to your year truck.
I'll ask, how did you break it?
Old Dec 2, 2014 | 06:44 PM
jmasselli22
I was in the mud with some deep ruts. i flexed my CV joint in 4x4 too far and it broke. brought it to my mechanic and i was told i the axle is far beyond repairable. i spoke to the receptionist not the actual mechanic and i am a bit confused on whether she understands that i dont need a whole new axle just half; unless both sides are broke. she is also telling me that the axle will be $250+. if you could post the links to some good CV axles that i could use on my truck so that i do not have to go with her $250 option it would be much appreciated.
Old Dec 2, 2014 | 06:46 PM
jmasselli22
also, to repair it, would a half CV axle assembly be all i need or do i need anything else?
Old Dec 2, 2014 | 06:55 PM
00DakDan's Avatar
00DakDan
Section Moderator
I can see it costing $250 at a shop, easily.
All you need is a "half-shaft assembly"
Check out rockauto like sxrsil3nt says. They have a variety of them from about $40 and up. Get a good one!
Old Dec 2, 2014 | 07:04 PM
jmasselli22
CARDONE SELECT Part # 663991IS {#52069708, 52069708AC, 52069886AB, 52069886AD, 52069886AE} New CV Intermediate Shaft One of our most popular parts
Front Right
SURTRACK Part # MI8076 Does Not Include ABS Ring
Front Right; 4WD
Front Left; 4WD
any advice on these ones? what is an ABS ring and how important is it?
Old Dec 2, 2014 | 07:05 PM
jmasselli22
i found both of these on rockauto.
