no spark yes i did research
Old Dec 10, 2014 | 08:19 AM
  #21
AtomicDog's Avatar
AtomicDog
Check eBay for a used PCM. I bricked my PCM once when I tried to flash it via an SCT tuner. Found a used PCM on eBay and when it was delivered, I swapped it out and the truck started right up.
Old Dec 11, 2014 | 07:25 AM
  #22
dipsherry's Avatar
dipsherry
what year pcm will work the truck is a 97 the new motor is a 98 but i used the 97 harness. And yes the truck ran fine for two weeks before this issue so i know it has nothing to do with the swap
also yes i have tested the injectors they are pulseing. So that means the ASD is functioning correct?
Old Dec 11, 2014 | 10:13 AM
  #23
00DakDan's Avatar
00DakDan
Section Moderator
The ASD is working if you get power to the injectors.
I don't think the 5.9 was available in '97. You could try a '98 PCM.
Do not even attempt running any PCM from '01 and up, the computer bus changed.
Old Dec 12, 2014 | 08:16 AM
  #24
dipsherry's Avatar
dipsherry
ok so figured i would give the truck a shot this morning. no it didnt start but now for whatever reason as soon as i turn my key in the run position my running lights come on.
Old Dec 12, 2014 | 11:18 AM
  #25
00DakDan's Avatar
00DakDan
Section Moderator
The parking lights or DRL's?
Neither are run off of the CTM or PCM in a '97.
Sounds like there may be a bad ground if weird things are happening.
Old Dec 12, 2014 | 03:15 PM
  #26
98DAKAZ's Avatar
98DAKAZ
Ground for the PCM? corroded lose?
Old Dec 12, 2014 | 04:03 PM
  #27
00DakDan's Avatar
00DakDan
Section Moderator
Missing engine ground straps?
Old Dec 13, 2014 | 08:20 AM
  #28
dipsherry's Avatar
dipsherry
the parking lamps now its not doing it. IDK i ran all new ground with 2gauge wire so i know its not a grounding issue. i think the truck is possessed.
Old Dec 13, 2014 | 10:14 AM
  #29
98DAKAZ's Avatar
98DAKAZ
Ok possessed is how my Dakota acted when my PCM freaked out on me but I had bucking, stalling, Idle problems, hard starts, engine cut outs just the strangest things happening.
The very strange thing is at times it ran great
Old Dec 13, 2014 | 04:36 PM
  #30
magnethead's Avatar
magnethead
Do you get 5 volts at the sensors?
