Fog Lights not working 2002 Dodge Dakota SLT 4.7 L 2wd
Fog Lights not working 2002 Dodge Dakota SLT 4.7 L 2wd. I have changed out the lights, relay and fuse. I just got this from a used Car lot and I am trying to fit all of the issues with the truck. When I looked at the fuse block the fuse was missing. Is there a switch other then the marker/headlight switch?? I am looking for a wire diagram for the fog light. Also I am looking for a fuse block diagram with fuse and relay info. I have fuse/relay on the cover, but I see that the information on the cover in some area dont have fuses, example 2 spaces below the fog light fuse (25 amp R Blwr). What is R BLWR Also I have a trailor hitch and wire harness for a trailor, but in the fuse block trailor 1 fuse is in, but trailor 2 fuse is not. Can someone help me ..
Thanks
Thanks
Hi Glewis,
Welcome to the forum.
There is just the one switch. The headlight have to be on, low beam, for them to work.
You can download a manual from here - use the '01 link as there are only very minor changes.
https://dodgeforum.com/forum/2nd-gen...-download.html
The manual is in .rar format. You can download a free converter, such as WinRAR, to save it as a pdf file.
R Blwr is "rear blower". Remember, the Durango is almost identical and shares many of the same components.
Thank you. for both the link to the manual and the switch. I have tried the headlight when I changed out the fuse relay and lights.. So most likely its the switch or wire harness. Again thanks
Hi Glewis,
