trans fluid change?
I am changing the trans fluid on my 2000 dodge Dakota, and the fluid capacity says 4 qts, will I need that much or will just three qts do it? I was told that about a qt or so will stay in the truck, unless I get it flushed. is that true?
Check the fluid before beginning. If the level is fine, measure what drains out and put the same level back in. Understand that you're only changing roughly a third of the total capacity with a single drain and fill.
Do you have a manual for your truck Indigo?
I'm assuming it is the 42RE and not the NV3500.
TRANSMISSION FILL PROCEDURE
To avoid overfilling transmission after a fluid change or overhaul, perform the following procedure:
(1) Remove dipstick and insert clean funnel in transmission fill tube.
(2) Add following initial quantity of Mopart ATF Plus 3 to transmission:
(a) If only fluid and filter were changed, add 3 pints (1-1/2 quarts) of ATF Plus 3 to transmission.
(b) If transmission was completely overhauled, torque converter was replaced or drained, and cooler was flushed, add 12 pints (6 quarts) of ATF
(3) Apply parking brakes.
(4) Start and run engine at normal curb idle speed.
(5) Apply service brakes, shift transmission through all gear ranges then back to NEUTRAL, set parking brake, and leave engine running at curb idle speed.
(6) Remove funnel, insert dipstick and check fluid level. If level is low, add fluid to bring level to MIN mark on dipstick. Check to see if the oil level is equal on both sides of the dipstick. If one side is noticably higher than the other, the dipstick has picked up some oil from the dipstick tube. Allow the oil to drain down the dipstick tube and re-check.
(7) Drive vehicle until transmission fluid is at normal operating temperature.
(8) With the engine running at curb idle speed, the gear selector in NEUTRAL, and the parking brake applied, check the transmission fluid level.
CAUTION: Do not overfill transmission, fluid foaming and shifting problems can result.
(9) Add fluid to bring level up to MAX arrow mark. When fluid level is correct, shut engine off, release park brake, remove funnel, and install dipstick in fill tube.
i found an external filter, and other info. iam big on using steel fuel, and trans cooler lines when you can. use ONLY steel brake lines. copper WILL break off. the factory uses steel for a reason!!!! mopar most use 3/8 dia tube, but some might be 5/16. i think most have the fluid in at the rear left side. here is an EXTERANL filter, i found. have one on my 01 dak. my idea is when you put a new filter in side this one will help from having to do the inside one as often.*
the old auto zone 2210 magenfine filter is no longer available at auto zone. BUT i did find the same thing as JX-160 brand-- ATP. at a real parts house uses 3/8" tube. a JX-150 for 5/16 tube. ONLY use high pressure hose. If you must. SAE J1019 217 psi working. NOT fuel hose for a carb engine.
