3.9 Refuses to Idle when Cold
Old Jan 6, 2015 | 10:49 AM
Katmandu's Avatar
Katmandu
Question 3.9 Refuses to Idle when Cold
When the tempertures go below 30 degrees outside, my 3.9 will not idle when the engine is cold.
I need to hold the throttle above 1,000 RPMs for 4-5 minutes until the engine will idle by itself.
What do I need to be checking here ?
TIA
Old Jan 6, 2015 | 11:05 AM
00DakDan's Avatar
00DakDan
Section Moderator
Do you have any codes?
Have you cleaned the throttle body and IAC lately?
Old Jan 6, 2015 | 11:20 AM
Dodgevity's Avatar
Dodgevity
Good idea.
I was having issues with idle too, it would get real erratic and sometimes shut off when coming to stop. This is even when hot. I cleaned the TB and IAC. It seemed fine for a month or so, then returned with a vengeance. I replaced the TPS sensor and it's been rock solid ever since.
Old Jan 6, 2015 | 12:02 PM
Katmandu's Avatar
Katmandu
No codes and Yes and No.
I'm sure the IAC need a good cleaning as well..
Is the IAC the only thing that would keep it from idling when cold ?
Old Jan 6, 2015 | 12:35 PM
00DakDan's Avatar
00DakDan
Section Moderator
The IAC controls the idle speed. If it's too low you'll stall.
Could be other issues, maybe the PCM isn't going into "open" loop due to a bad temperature sensor. May also be a TPS issue, MAP sensor, etc. How's the battery voltage too? Dakota's are sensitive to low voltage, even if it does start.
Old Jan 8, 2015 | 11:11 PM
dodgeramguy85's Avatar
dodgeramguy85
Clean your battery connections and also get the battery load tested. These trucks need the right amount of volts to run right. I would also clean the throttle body tho too.
Old Jan 10, 2015 | 02:04 PM
Katmandu's Avatar
Katmandu
Thumbs up
10-4.
I ordered a new IAC off EBay for $9.50 Shipped. Should be here any day now.
Old Jan 10, 2015 | 03:06 PM
magnethead's Avatar
magnethead
Originally Posted by Katmandu
10-4.
1. why ebay
2. why ebay
3. I hope it works...
Old Jan 16, 2015 | 01:33 AM
Katmandu's Avatar
Katmandu
Originally Posted by magnethead
1. why ebay
2. why ebay
60% less than the same part # here at local stores. Hope to install it in the next couple days. Time..... anyone have some extra to give me ? LOL !
Old Jan 16, 2015 | 10:24 AM
Dodgevity's Avatar
Dodgevity
Hope it's Mopar. Personally I would have gotten the TPS first.
