Won't Start - No Electrical Power
Old Jan 24, 2015 | 12:22 PM
Katmandu's Avatar
Katmandu
Exclamation
Originally Posted by bsl
Working through the checklist of easy things first, fuses are good and the battery posts are not bad (current to the ends of the wires just past the battery posts).
So, that leads to a problem in the wiring. Dumb question, but is there an in-line fuse in the wiring harness? I am getting a little caught-up in that the engine had turned over and wipers started just before everything died. Maybe the ground connection went bad all of a sudden?.
Check the Positive battery cable down to the STARTER. Check for a loose connection and/or break in the cable.
I had a Positive battery cable break down near the starter and lost ALL electrical power to the vehicle just like yours.
Old Jan 26, 2015 | 11:31 AM
bsl's Avatar
bsl
To give a quick update, was able to jump-start the truck this morning. Wasn't able to get the battery out last week, but am going to do that today for load testing, and replace if necessary (otherwise, will get it towed).
Thanks all for input and help! If battery takes car of the issue now, I will then start working trough some of the wiring as the weather lifts (possitive cable to starter, ground cable and connections, splicing to PDC, etc.).
Old Jan 26, 2015 | 12:30 PM
00DakDan's Avatar
00DakDan
Section Moderator
I wouldn't be surprised if the battery was the problem. They can just fail.
Old Apr 17, 2015 | 02:25 PM
bsl's Avatar
bsl
Bit of an overdue catch-up, but it was the battery--thanks for the input and guidance all!
I also have found that the cigarette lighter is only powered when the truck is on or in accessory mode. My speculation on this is that the previous owner installed an aftermarket radio, and something got changed around in the installation process.
One thing that has happened since switching the battery is the RKE doesn't work--I replaced the batteries in the fob, but it is not interacting with the truck at all. Going to check the connection in the driverside kick panel tonight, but is it possible that it needs to be reprogrammed to the truck after not having a battery for a day?
Old Apr 11, 2021 | 11:12 AM
Ernst.joel's Avatar
Ernst.joel
I had this exact issue happen yesterday I thought it was the battery at first and tried to jump it but I noticed after a while the cables weren't sparking when I adjusted the cables. So I went to take out the battery to get it tested when I noticed I had a loose connection on my negitive terminal after tightening it my truck is working again. Hope this helps
Old Jun 26, 2023 | 02:08 PM
Rick32's Avatar
Rick32
Default Help
Omg so happy to find y'all topic I'm having the same exact issue with my ram battery is good everything's in good looking order tight connections for my grounds it seems truck will run fine for a few days then all of a sudden one day get in Kia click all the way to the end lights will come on soon as I go to start it just clicks then all the lights flicker on my dome light and my ctm I can hear clicking it doesn't seem like I have any loose connections I'll double check though I do know I have a couple breaks in my negative wire one on the bend to the alternator and the other on the bench going into the fuse box they're not huge but you think that could cause an issue
Old Apr 17, 2025 | 08:44 AM
That_az_whole's Avatar
That_az_whole
Having the same issue on my 2000 dodge dakota slt 3.9l was working fine yesterday than went to start it up to head to work and it cranked over but didn't stay running so I tried again and that's when I lost all power
Old Apr 17, 2025 | 10:53 AM
How's the battery? Battery cables? Do you get ANY power at all when you turn the key to Run?
Old Apr 17, 2025 | 10:58 AM
That_az_whole
Battery is somewhat new, the cables have a little corrosion on them, and there's no power like at all. The dome lights don't come on when u open the door and there's no binging when u put the key in the ignition when the doors open. But I did a little more digging into wires and found that one of my 12 volt battery wires for my radio was grounded out pretty bad for the wiring harness
Old Apr 17, 2025 | 10:59 AM
Yep, verify your battery has good voltage. (north of 12 volts at rest) Check/clean both battery cables at the battery. See what happens.
