Truck whistling sound
Old Jan 31, 2015 | 07:30 AM
rut250's Avatar
rut250
Default Truck whistling sound
I got no codes for vacuum leak I did check the lines and did find dry rot that I replaced I got one code for very small evap leak. I was thinking that I needs to replace the valve cover gaskets there leaking oil a bit. Would that be were I hear it to? Anyone got a diagram for vacume hoses. I might of missed one
Old Jan 31, 2015 | 09:52 AM
00DakDan's Avatar
00DakDan
Section Moderator
What engine do you have Rut? There should be a vacuum hose routing diagram under the hood.
When does it whistle? Have you ruled out the accessories? Take the belt off for a minute or so and see what happens.
Old Jan 31, 2015 | 01:32 PM
rut250's Avatar
rut250
Driving about 60-70kmh 1500-2000 rpm. 3.9l . I replaced some vacuum hoses from dry rot
Old Jan 31, 2015 | 01:48 PM
rut250's Avatar
rut250
Also my egr valve is ticking all the time. Tick,tick,tick is that normal maybe it's a evap leak making the sound
Old Feb 1, 2015 | 11:36 PM
rut250's Avatar
rut250
Took the belt off I couldn't hear anything
Old Feb 2, 2015 | 01:43 PM
00DakDan's Avatar
00DakDan
Section Moderator
So the whistle stopped? Check your accessories, the alternator, p/s pump, a/c compressor, water pump, and the idlers. Spin them over. They should turn smoothly.
You might have a bad bearing on one of them.
I didn't think an '02 3.9 would have an EGR valve?
Old Feb 2, 2015 | 10:14 PM
moe7404's Avatar
moe7404
can she whistle little brown jug? LOL LOL
Old Mar 5, 2015 | 06:43 PM
rut250's Avatar
rut250
Took a short vid it gets a lot louder at times. Checked pullies all seemed good. My belt tensioner was sized pritty good but oil freed it up and no change.http://youtu.be/RPoBQYF9NgE
Old Mar 5, 2015 | 07:05 PM
00DakDan's Avatar
00DakDan
Section Moderator
Is it louder in the cab or outside?
Replace the tensioner. Oiling it won't last. If it seizes you're stuck.
Old Mar 5, 2015 | 09:50 PM
rut250's Avatar
rut250
I only hears it driving. I can never hear it in park Reving the motor Not sure u herd it in the vid or not but it's driving me nuts.
