Looking at a very high mileage Dakota Quad cab
02-06-2015, 04:32 PM
Section Moderator
Dodge Forum Moderator
The option code is DSA. You might see anti-spin or something similar. Ask the owner, he should know.
To do it right the timing cover would need to come off. You can't access the 3 chains otherwise. I don't know the cost.
02-06-2015, 07:00 PM
Quote:
Originally Posted by
00DakDan
One concern, the timing set calls for an inspection at 250k.
I haven't had mine checked. I use good oil, keep it topped off and hope for the best. LOL
02-09-2015, 05:48 PM
on
Check for excessive play in the rack-n-pinion.
My 98 2wd w/251k has worn rack.
02-09-2015, 05:58 PM
Section Moderator
Katmandu
Are you sure it's the rack? A more common problem is the intermediate shaft.
02-12-2015, 11:47 AM
on
00DakDan
I'm not for certain. A mechanic took a quick look and diagnosed it.
I need to look myself. After it gets warmer outside!
02-12-2015, 12:46 PM
on
Thats way over priced for the miles, even if they are all "highway" miles.
