Need Help- Suspension/BUshing work
Old Mar 11, 2015 | 03:48 PM
  #21
00DakDan's Avatar
00DakDan
Section Moderator
The instructions from Moog say to put the nuts on top. I agree with 98DakAZ that the bottom makes sense. When I did my ball joints the first time I had them on the bottom and didn't notice anything, they still lasted 80k miles.
This time I put them on the "right" way. Nuts on top.
Old Mar 11, 2015 | 04:09 PM
  #22
98DAKAZ's Avatar
98DAKAZ
Just one thing my Dad told me I tell you he knew a ton about autos and almost anything mechanical being an industrial production mechanic in a number or companys welding, electrical, fabrication, machinest and many other specialties.
Old Mar 11, 2015 | 05:18 PM
  #23
archemedes74's Avatar
archemedes74
I fix planes, and on them you bolt from the top so if the nut comes off the bolt stays (is actually something fineable by the FAA) so that's how I always do it
Old Mar 11, 2015 | 07:46 PM
  #24
00DakDan's Avatar
00DakDan
Section Moderator
Me too and I agree, but...
I also follow installation instructions. If it says to install something in a certain direction, I do.
Old Mar 11, 2015 | 10:43 PM
  #25
RalphP's Avatar
RalphP
Originally Posted by jondakotaguy
Ilooked at Raybestos i see alot of them are the same part listing for the ACdelco I'm wondering if they really are the supplier for some of those parts to GM or not...
ACDelco uses a bunch of relabelled Spicer parts. Which since Raybestos absorbed Spicer ...
Spicer Pro / the higher end Raybestos / the higher end AC Delco are all good parts so far.
RwP
Old Mar 11, 2015 | 11:37 PM
  #26
98DAKAZ's Avatar
98DAKAZ
Well the top ball joint is just a pivot point in the standard auto so it doesn't get a ton of forces on them so either nut up or down shouldn't matter. But if you off road race or on a track of any kind then the forces on that joint could be 10 X fold and their may be a reason for nut on top.
I don't remember on my new ball joints them saying what way the nut should be at all.
Old Mar 12, 2015 | 02:03 PM
  #27
jondakotaguy's Avatar
jondakotaguy
Well if the instructs says to 'nut up' Pun intended lol then we'll go with the nut up.. being i do off road..
Old Mar 12, 2015 | 02:07 PM
  #28
00DakDan's Avatar
00DakDan
Section Moderator
That's my thinking too. I haven't checked but the nut and length of the bolt may interfere with the spindle in certain positions whereas just the head of the bolt would clear.
Old Mar 12, 2015 | 02:12 PM
  #29
jondakotaguy
i could see that under full lock and at certain positions.. in an off road condition or something.
Old Mar 12, 2015 | 03:34 PM
  #30
98DAKAZ's Avatar
98DAKAZ
Talking
No no no bolt on top just kidding
