need help with transmission
Old Mar 2, 2015 | 11:35 AM
dodgedakotaslt's Avatar
dodgedakotaslt
when I check the hydraulic pressure wat should it be.
Old Mar 2, 2015 | 12:29 PM
00DakDan's Avatar
00DakDan
Section Moderator
The pressure varies. Tests are done at 1500 rpm.
Basically you want to verify:
1. You have pressure.
2. It matches up with what the line pressure transducer is measuring.
If you want to start checking all the clutch pressures, you'd need a valve body pressure tap adapter:
N-R, 220 psi.
Most other shifts vary from 100-120psi.
If you've had a pump failure you aren't moving, period.
Old Mar 2, 2015 | 06:23 PM
dodgedakotaslt
Will i need a hydraulic pressure test set or could i use something like my manifold gauges for my ac
Old Mar 2, 2015 | 06:48 PM
00DakDan's Avatar
00DakDan
Section Moderator
As long as the gauge can handle the pressure and you can make it work, you're good.
Old Mar 2, 2015 | 06:51 PM
archemedes74's Avatar
archemedes74
just remember the fluid will enter the gauge assembly, so you run a risk of contamination
Old Mar 2, 2015 | 07:13 PM
dodgedakotaslt
Ok better off just getting a hydraulic tester wats the best tester should I get
