98 Dakota 3.9 Stalls
Old Mar 18, 2015 | 07:53 AM
imdyinhere's Avatar
imdyinhere
Default 98 Dakota 3.9 Stalls
Hi. New member here.
I recently bought a salvaged 98 Dakota with 174k miles. The truck needs a lot of work but the one thing I really need help identifying is the stalling issue.
The issue is intermittent at best. The truck stalls when idling. I took it to a shop and they tried to tell me it was the clutch but I am not having any issues with shifting, putting in gear, etc. The stalling seems really random. Since I don't know much about these trucks, is there anyone who might be able to give any insight as to why this might be happening?
Thanks.
Old Mar 18, 2015 | 04:03 PM
98DAKAZ's Avatar
98DAKAZ
Wink
More info would help is an auto or stick other things like what have you done to it to date is helpful.
Old Mar 18, 2015 | 04:16 PM
imdyinhere's Avatar
imdyinhere
3.9L V6 5-speed. Base model 2wd, standard cab, long bed. Has a brand new alternator and replaced the 80A fuse while I was at it. Starts like a champ every time.
Old Mar 18, 2015 | 08:08 PM
00DakDan's Avatar
00DakDan
Section Moderator
Welcome to the forum.
Take the throttle body off and clean it, especially the IAC passages.
Old Mar 19, 2015 | 01:21 PM
Robertwav1's Avatar
Robertwav1
Throw some wire ties around the PCM plugs. Cheap and easy, see if it helps.
Old Mar 19, 2015 | 04:39 PM
imdyinhere's Avatar
imdyinhere
Thanks Ill give that a go.... Im not very handy when it comes to this stuff though... Difficulty on a scale from 1-10 for someone with little Mopar experience?
With regards to the PCM, are you suggesting it might be only a connection issue?
Old Mar 19, 2015 | 05:05 PM
98DAKAZ's Avatar
98DAKAZ
try this LINK
Old Mar 19, 2015 | 05:14 PM
theJester517's Avatar
theJester517
My truck has been stalling intermittently and i've found jiggling the pcm connectors will make it stall on cue. this might be your problem. I also have backfiring and auto shutdown like it wont start after this. does that sound about right?
Old Mar 20, 2015 | 01:25 PM
imdyinhere's Avatar
imdyinhere
Not really. I haven't had any backfiring, and it usually starts right back up. Sometimes it takes a few cranks but it always gets running again.
Old Mar 20, 2015 | 01:26 PM
imdyinhere's Avatar
imdyinhere
Originally Posted by 98DAKAZ
try this LINK
Thanks 98DAKAZ. Ill try that this weekend.
