2001 Dakota
Old Mar 31, 2015 | 01:52 PM
coxstone11's Avatar
coxstone11
Default 2001 Dakota
Look for the change up sparkplugs for my 4.7L
I'm now using truck plugs champion 4071
Old Mar 31, 2015 | 02:00 PM
Stick with OEM. Welcome to the forum.
Old Mar 31, 2015 | 04:09 PM
00DakDan's Avatar
00DakDan
Section Moderator
OEM all the way. Champion RC12MCC4.
Old Apr 2, 2015 | 11:08 AM
coxstone11's Avatar
coxstone11
Default ticking at start up
Will these plugs stop ticking noise at startup .
Thanks for your time
Old Apr 2, 2015 | 11:11 AM
No. Plugs have nothign to do with the ticking. Thats lifter noise and won't hurt anything. You could try switching oils, but not really a lot you can go about it.
Old Apr 3, 2015 | 02:47 AM
olsarge's Avatar
olsarge
The ticking could also be a broken exhaust manifold bolt.
Old Apr 11, 2015 | 02:46 PM
coxstone11's Avatar
coxstone11
Default Engine tick at first start up
The tick Im getting is at first start up and just starting happening after i changed my truck plugs to platinum , that is why Im wondering is there a plug that is good as the champion truck plugs i had , they just dont make them any more. Im running cold air intake and g-force chip.
thanks for time
Old Apr 14, 2015 | 01:57 PM
Robbadodge's Avatar
Robbadodge
As stated, the ticking is normal and has nothing to do with spark plugs. Just call it odd that you only heard it after changing to a different spark plug. Maybe now your windows are open due to the warmer weather and the timing goes with new plugs.
In any event, they tick, even with 240K+ miles.
Good luck!
Old Apr 14, 2015 | 02:16 PM
Could be your g-force chip. Mystery snake oil has been known to cause other issues....
