Does my Dakota have Infinity system?
Old Apr 3, 2015 | 09:44 PM
usaftrevor87's Avatar
usaftrevor87
Default Does my Dakota have Infinity system?
This might be a dumb question, but do all the Dakotas have the infinity amp system? If they all don't have it, how do I know if I have it or not?
I have a 2000 Dakota SLT 4.7L Club Cab
Also just to clarify, i am going to install an aftermarket kenwood system. IF my Dakota has the Infinity Amp all I need to do is connect the Blue wire from the aftermarket harness to the Blue/white wire from the truck... right?
Thanks in advance.
Old Apr 3, 2015 | 10:08 PM
00DakDan's Avatar
00DakDan
Section Moderator
Welcome to the forum Trevor.
No. Not all Dakota's have the Infinity system. If you do, you'll have separate tweeters on the front doors, about 2" in diameter. It should say Infinity on the grill.
If you are using a harness adapter follow what the directions list. The colors are not the same as the factory harness. The actual "amp remote" wire on your trucks harness is dark green with a red tracer.
Old Apr 4, 2015 | 09:44 AM
usaftrevor87
Oh ok, awesome. I do not have the amp then. Should be an easy install then haha thanks
