Transmission being swapped need maintenance advice
Old Apr 22, 2015 | 08:38 PM
Bizzaro's Avatar
Bizzaro
Default Transmission being swapped need maintenance advice
I'm having a shop do a transmission swap. While it's out is there anything I should perform maintenance to due to the accessibility.
Old Apr 23, 2015 | 04:38 PM
00DakDan's Avatar
00DakDan
Section Moderator
How are your freeze plugs? There are some on the back that are only accessible with the tranny removed.
Check the u-joints too.
Old Apr 23, 2015 | 04:47 PM
Bizzaro's Avatar
Bizzaro
I do have one on the side leaking. I seen a kit that contains brass freeze plugs are those supposed to be better? I will also inspect the U joint thanks for the help.
Old Apr 23, 2015 | 06:34 PM
00DakDan's Avatar
00DakDan
Section Moderator
Yes. Brass won't rust.
Still, steel plugs should last quite a while if you maintain the cooling system.
Old Apr 23, 2015 | 09:48 PM
Dodgevity's Avatar
Dodgevity
Get a pan with a drain plug. Last I saw, Advance had one for cheap... Dorman brand. That way you can do the best maintenance of draining it every 30K or so. Don't know which tranny you have. It has a spin on filter, get the Mopar, because it has an anti-drain back valve.
