2001 dodge dakota timing chains
Old Apr 30, 2015 | 04:14 PM
jws123's Avatar
jws123
Default 2001 dodge dakota timing chains
I have a 2001 dodge dakota 4.7 150k on it i replaced all timing chain tensioners and guides when it starts cold the chains knock for about 5 mins until it gets warm once its warm it is fine no noise i guess this is a common issue but should i be using thicker or thinner oil i currently use 10w30.?
Old Apr 30, 2015 | 04:43 PM
00DakDan's Avatar
00DakDan
Section Moderator
If you check your oil filler cap it should say 5w-30, mine does anyways. I've never noticed a knock, 141k so far with the original chains.
Old Apr 30, 2015 | 05:49 PM
jws123's Avatar
jws123
I saw that but was hesitant on trying thinner oil but i guess il give it a shot
Old Apr 30, 2015 | 06:44 PM
00DakDan's Avatar
00DakDan
Section Moderator
The engine was designed for it, not an issue. I've only run 5w-30 in mine since new.
