maintenance schedule for 04 dakota
Old May 9, 2015 | 08:02 AM
singledad's Avatar
singledad
Smile maintenance schedule for 04 dakota
hello to all. Lets get to the point.
I bought a 2004 dodge Dakota SLT quad cab 2wd with the 4.7L V8 in it just recently. Bought from an old man who only put 28k miles on it. So pretty much i have a very fresh V8 and that i am taking care of. From what i know this is what has been done currently to the truck for maintenance recently.
** All fluids flushed (brake, power steering, tranny, oil, radiator)
**new brake pads
**New Monroe struts in the front (left front had been bent)
I don't have a owners manual. So on these Dakotas, its there anything i would have to replace down the road as part of preventive maintenance?? I want to make sure that i am taking care of my truck properly.
also, how often does the differential fluid in the axle gave to be replaced? thanks
Old May 9, 2015 | 05:03 PM
magnethead's Avatar
magnethead
engine every 3K
trans and differential every 25K or every 3 years unless it goes through water often
steering intermediate shaft every 75K or 5 years or so (joints in it stiffen easy)
balljoints and control arm bushings every 50-100K or so (some last longer than others)
radiator flush every 3 years, make sure to reverse flush the heater core as well.
I'd call that a starting point knowing the history on these trucks.
Old May 9, 2015 | 05:31 PM
98DAKAZ's Avatar
98DAKAZ
I never go by the service schedual I inspect everything every year manual transmission should be around 5 to 7 years or longer. Rear Diff 50 or 75K
Old May 9, 2015 | 07:12 PM
00DakDan's Avatar
00DakDan
Section Moderator
If you have the Trac-Loc differential change the fluid AT LEAST every 30k. You don't need/want the clutch material destroying bearings.
Old May 10, 2015 | 08:38 AM
Dodgevity's Avatar
Dodgevity
Wow, 28K??? I bought my 03' with nearly 250K! That truck must've sat a lot, so check the hoses and belts for cracks + oil leaks at seals. Also check tires for dry rot, if original. I would convert the PS fluid to ATF+4 and change both filters in the transmission.
Be sure to post up some pics and check the sticky above for factory service manual in PDF format.
Old May 10, 2015 | 09:43 AM
Inspect the brakes as well. If it still has oem pads/shoes, they probably need to be changed or at least inspected.
