hard steering problem
Old May 12, 2015 | 08:08 PM
zeus661's Avatar
zeus661
Default hard steering problem
I need help figuring out why it is hard to turn the wheel on my truck.
It is a 2002 Quad Cab 4WD with a 4.7. 182,000 miles.
Turning the steering wheel sees to take more muscle than it has in the past. After making a turn the wheel requires help to return to the straight position or even close to straight. Fluids are up and the belt is tight. Where should I look first and how?
Old May 12, 2015 | 08:11 PM
00DakDan's Avatar
00DakDan
Section Moderator
Hi Zeus,
It's a common problem. The u-joint in the lower intermediate steering shaft has seized. Replace the shaft.
You can try putting some penetrating oil on it temporarily. You will need to replace it however.
Old May 12, 2015 | 08:23 PM
zeus661's Avatar
zeus661
I have read it could be the shaft. Any tricks to replacing it? Anything I have to take off before? Do's and don't?
Old May 13, 2015 | 02:22 AM
98DAKAZ's Avatar
98DAKAZ
Yes you could do some real damage if done wrong and cost you around $200 to fix please read the service manual and follow it.
You can download the service manual on this forum look on the top of the forum for the 2-gen Dakota.
Old May 13, 2015 | 05:22 PM
00DakDan's Avatar
00DakDan
Section Moderator
Hit the bolts with some penetrating oil the day before so they come out easily.
Do NOT turn the steering wheel once you disconnect the shaft. Use a seat belt, anything, to keep it from turning. If it turns, you can damage the clock spring.
It's not that bad, just awkward to reach the bolts. Hopefully the new shaft comes with replacements.
