1998/2003 fuel tank swap?
My 1998 standard cab 3.9L 5-speed daily driver has a 15 gallon fuel tank. I drive over 30 miles to work each way, so it seems like I'm always filling the tank, even though I average between 19-20 MPG. It just so happens that last year I bought a 2003 Club Cab 3.9L a/t as a parts truck, and it would likely have the 22 gallon tank, right? Will it work to just swap out the tank and fuel pump/sending unit from the 2003 into the '98 or are they not compatible?
Oh, I'm not complaining about my MPG's. The truck has 237,000 miles on it, for crying out loud!
It would just be nice to make less frequent stops, that's all.
You said to crawl underneath to check the capacity; is the fuel capacity stamped into the tank itself? And who exactly is Dan?
It would just be nice to make less frequent stops, that's all. You said to crawl underneath to check the capacity; is the fuel capacity stamped into the tank itself? And who exactly is Dan?
Just get the build sheet and it will tell you....
http://www.dodge.com/webselfservice/dodge/index.html
Click on 'equipment listing' on the left, then enter vin for instant build sheet.
Works for Jeeps too.
http://www.ebay.com/itm/FUEL-TANK-00-01-02-03-04-Dodge-Dakota-club-cab-2-door-22-gallon-R224483-/321754916286?fits=Year%3A2003%7CModel%3ADakota&hash=item4aea1665be&vxp=mtr
http://www.ebay.com/itm/97-99-Dodge-Dakota-22-Gallon-Gas-Fuel-Tank-with-Front-and-Rear-Support-Straps-/171623492083?fits=Make%3ADodge%7CModel%3ADakota&hash=item27f58ea9f3&vxp=mtr
Trending Topics
Thank you. I sort of figured the tank would drop in, but won't it require the use of the newer fuel pump as well? That's what has me wondering a little, as in the compatibility of the fuel and electrical connectors and whether or not the newer pump will work in the older truck.
Sorry, I said this wrong, earlier. According to the compatibility list, the earlier 22 gal will fit the later truck but not vice-versa. Makes no sense though. If one fits the other, they should interchange. So, I'd try it.
