tranny slippage
Old Jun 15, 2015 | 01:05 AM
shufly's Avatar
shufly
Default tranny slippage
2000 dakota 4.7L 4x4 auto: tranny leaked, replaced gasket n filter, repaired coolant line . now it slips a lil at start-off, takes longer time to engage. n reving in gear longer. higher rpm like over 3k up slight incline
Old Jun 15, 2015 | 08:11 PM
00DakDan's Avatar
00DakDan
Section Moderator
"gasket n filter" - you mean filters, plural right?
Did you use MOPAR filters? There are LOTS of problems with aftermarket filters not sealing correctly. You'll get air in the system and have all sorts of problems.
There is a TSB out, 21-015-05, that applies.
Don't keep driving it.
Old Jun 17, 2015 | 01:19 AM
shufly's Avatar
shufly
Default tranny slipping
yes i still drive it. just around town few times. i put gasket n filter 1st time n it fell off with the ring on it. 2nd time it seemed to have stayed on with the threaded grooves on it. that when i found out coolant line leaking. n ran fluid out hole n fixed
Old Jun 23, 2015 | 01:27 PM
Shufly2's Avatar
Shufly2
Default Slipping tranny
Ok mopar gasket , primary filter , n tsb. Need replace cooler return gasket also? I just rubber hosed inch or two of rusted cooler line. N use mopar fluid also?
Old Jun 23, 2015 | 02:33 PM
Dodgevity's Avatar
Dodgevity
I use Walmart Supertech ATF+4 in the tranny and PS. Works great.
Old Jun 24, 2015 | 09:19 AM
jondakotaguy's Avatar
jondakotaguy
You use what>>?? I'm never speaking to you again ROFL.. JK
Old Jun 24, 2015 | 10:16 AM
Dodgevity's Avatar
Dodgevity
Hey, it meets the specs so it's just as good as the rest, I've heard.
Old Jun 24, 2015 | 11:27 AM
04DakAz's Avatar
04DakAz
I used Supertech when i couldnt find any Valvoline and had no problems, I used the supertech fluid for Filling and Draining the Trans/Ps to get all the nasty old fluid out. It was $4.79 +/- compared to Valvoline $6.89 a Qt. Sadly Walfart doesn't carry Valvoline ATF+4
Old Jul 9, 2015 | 01:30 PM
Shufly2's Avatar
Shufly2
Default Slipping dodge dakota
Would I use tranny filter n gasket for v6 1995 Dakota n ATF+4 also?!'
Old Jul 11, 2015 | 07:08 AM
04DakAz's Avatar
04DakAz
I think you can, or you can use Castrol Import multi Vehicle $5.39 qt, It says it meets the ATF+3 spec. Choice is yours. I know the Castrol is cheaper than Valvoline ATF+4 $7.19 qt but if you want ATF+4 you can get Supertech ATF+4 from walfart for $4.27 qt
