squealing noise
Old Dec 28, 2019 | 10:47 PM
volaredon's Avatar
volaredon
Busted motor mount allowing the engine to rock when under heavy load? That would cause fan to hit the shroud. Probably nothing to do with the wreck being as how you were hit from the back. Not a terribly expensive repair. I've had to replace them in all but 1 of the Dakotas that I have had.
Old Sep 6, 2021 | 10:31 AM
SertlTheTurtle's Avatar
SertlTheTurtle
Default 2002 3.9l 5 speed dakota sxt
I had the same problem with the squealing sound then no clutch and a line had blown off. Not saying it will solve your problem but i had to change out the master slave cylinder to fix the issue. Not one single problem since i changed it
Old May 11, 2022 | 12:46 PM
thunderredd's Avatar
thunderredd
Default blown line on tranny
Originally Posted by Tavian
I have a 98 dodge dakota 3.9l 5 speed everything was shifting fine then all of a sudden a really loud screeching noise happened them there was no clutch I looked under the truck and there was a line that blew coming from the tranny. Anyone know why it did that and what to do
My guess would be a clogged filter or screen. or your torque convertor pressure is not working correctly.
