Fuel temp sensor
Old Aug 14, 2015 | 04:29 PM
rut250's Avatar
rut250
Default Fuel temp sensor
I just got a code from my truck saying fuel temp sensor (a) range/performance anyone know what/were it is I can't find anything on it
2002 3.9 2 wd sport
Old Aug 14, 2015 | 09:40 PM
00DakDan's Avatar
00DakDan
Section Moderator
What's the code itself? That's a diesel code - usually.
Old Aug 18, 2015 | 08:42 PM
rut250's Avatar
rut250
Old Aug 19, 2015 | 08:14 AM
00DakDan's Avatar
00DakDan
Section Moderator
Try it without the reader.
With the truck not running, turn the key to RUN, then OFF, back to RUN, then OFF again. Finally, turn the key to RUN and leave it. Codes will display in the odometer window. It'll say P DONE when finished.
That code does not apply to your engine. It would be "Fuel Injection Pump Failure" and is a diesel code.
Old Aug 19, 2015 | 12:49 PM
rut250's Avatar
rut250
So it could just b the reader. 25$ off eBay from China. Maybe it's time to spend the money to get a good one
Old Aug 19, 2015 | 04:59 PM
00DakDan's Avatar
00DakDan
Section Moderator
You don't need a reader, not with a Dakota. Just try to pull the code as I described.
