Lifting 97 dakota
Old Aug 15, 2015 | 03:32 PM
gavakie's Avatar
gavakie
Default Lifting 97 dakota
So Im looking to change the stance of my truck. I have a 97 v8 4wd. Doesn't have to be a suspension like I said just changing the look. Any suggestions on a kit. How difficult are they to do?
Old Aug 17, 2015 | 08:05 AM
Crank the torsion bars and get some blocks or add a leaf for the rear.
Old Aug 17, 2015 | 08:50 AM
colormeblue's Avatar
colormeblue
How many inches are you going for?
Old Aug 19, 2015 | 01:42 PM
jondakotaguy's Avatar
jondakotaguy
Torsion crank you can get about .5-1.5 (Some say 2" ) lift on front more of a level job unless you put the blocks on the back which you can use universal.
Body lift you can get a 2" or 3"
they offer full suspension kits for our truck up to 3" but is like 1-1.5K for the kit. Not really worth it IMO..
I did mine... torsion cranks + 2" body lift and 32" tires i gained about 5-6 " total lift..
My post and pics before/after are on the before after sticky in the root of 2nd generation general board.
https://dodgeforum.com/forum/2nd-gen...d-after-7.html
Old Aug 21, 2015 | 09:39 PM
Tom A's Avatar
Tom A
Section Moderator
The easiest/cheapest way to gain significant altitude is with a body lift. It's about $300 and should take about a day to install. That will give you 3" of lift, which should let you comfortably run 33" tires.
You can also do the torsion bar crank, which should net you another 1.5" or so, and make your truck look pretty good without having to spend a ton of money.
There is a bolt-on 5.5" kit available, but it's expensive, a lot of work to install, and isn't all that well built, IMO. I wouldn't go that way (again, lol).
Or, you can go all-out and put a solid front axle in it...
Old Aug 23, 2015 | 07:34 PM
44dakota's Avatar
44dakota
I wouldn't go any bigger than 33s with stock front end anyways..body lift and torsion crank will be able to fit 33s..
Old Aug 27, 2015 | 06:40 PM
jondakotaguy
I love your SAS.. looks very 'stock' compared to some others i see around and love it..
wanna come do mine? LOL
Old Aug 27, 2015 | 08:05 PM
44dakota's Avatar
44dakota
lol,im still working on this one, still needs front driveshaft, rear shocks, modify trans crossmember,new y pipe(to fit front driveshaft) bump stops, change rear 6 lug to match front 5 lug and the list goes on, but, im getting there..
Old Aug 28, 2015 | 03:52 PM
jondakotaguy
looking good.. dont forget to post before/after post all your photos. :P
