Gear indicator flashing all gears
Old Nov 14, 2015 | 08:23 PM
reedytlr's Avatar
reedytlr
Originally Posted by 00DakDan
There are differences in the PCM between the two years - basically due to a change in bus design from 2 wire (2000) to 1 wire (2001).
What about the TCM? Are they the same?
Old Nov 14, 2015 | 09:13 PM
00DakDan's Avatar
00DakDan
Section Moderator
Same issue. Dodge went from a 2 wire CCD bus to a 1 wire PCI bus in '01. Everything in the truck, the PCM, TCM, cluster, airbag module, the trip computer and more is different.
Old Nov 22, 2015 | 02:10 PM
reedytlr's Avatar
reedytlr
Well I fixed it somehow. Lol. Before you told me that the TCM was different also, I had switched them out several times trying to get something to work. After you told me they were different, the one out of the 2000 model was in the truck, and I had some other stuff to do so I hadn't switched them back yet. Well yesterday I went ahead and put the 2001 TCM back in the truck and just turned the key on and all the lights were still on and the gear indicator was still flashing. I didn't start it because I was in the process of switching fuel tanks and sending units between the two trucks. I put the other tank and stuff on and fired the truck up and everything worked perfectly lol. All the warning lights were gone, the gear indicator wasn't flashing, and it would roast the tires down my driveway. I'm not exactly sure what happened, but I'm not complaining lol
Old Nov 22, 2015 | 08:24 PM
00DakDan's Avatar
00DakDan
Section Moderator
Glad you got it.
