hi/lo headlight beams issue
Old Nov 23, 2015 | 04:35 PM
mechanic80's Avatar
mechanic80
Default hi/lo headlight beams issue
I have a distinct lo beam circuit and a separate hi beam circuit. Each position lights up only one of the two elements in the 9007 Bulb. But when I lift the stalk to go from hi to lo and hold it up, BOTH elements come on and it's like daylight! releasing the stalk at that point reverts to only the lo beam filament. Is this normal? The Hi beams only throw light further away and further down the road without any real increase in lighting output. I was thinking either somethin's wrong (the switch perhaps) or a remedy could be accomplished with a pair of relays, Anyone ever notice this? Any solutions to be had? There really is a huge difference when the lo and hi circuits are both active. Try it.
Old Nov 23, 2015 | 06:26 PM
00DakDan's Avatar
00DakDan
Section Moderator
It's normal for both high/low beams to come on when you pull back on the stalk. It's called "flash to pass."
Old Nov 23, 2015 | 10:08 PM
RalphP's Avatar
RalphP
"Flash to Pass" is designed to really, REALLY get the attention of the person you're flashing (like that DuraMax 3500 who's decided he wants to be in your lane headed the other way ...)
I wouldn't leave it on long - the wiring is NOT designed to support all that current for very long.
RwP
Old Nov 24, 2015 | 09:16 PM
jondakotaguy's Avatar
jondakotaguy
now if you could have them both running at the same time it would be like running modern projector style beams..
I really want projectors on my rig just the reviews for those Projectors are **** poor.
I've always appreciated the quality of light from both hi and low at the same time.. lol. I wish they would have just added high beam filiment activation instead of cutting lows off.. it would infact help you better see the road.
Old Nov 26, 2015 | 12:38 AM
RalphP's Avatar
RalphP
Actually, two things - 1) In a dual-filament bulb, having both on very long will usually overheat the bulb, causing it to fail. 2) No, having both on at the same time won't necessarily help you see further down the road, as a matter of fact, by having so much near field light, you can cause distance blindness (to see a stronger effect of this, turn on your dome light and see how much closer your "It's too dark out there!" point is ... )
But if you absolutely want both - add a set of driving lights to your truck. Use them instead of the high beams.
RwP
Old Nov 27, 2015 | 01:25 PM
totalrecall's Avatar
totalrecall
Hi - if this interests you - I had tried the following when I had my 2002 Chevy Silverado - same issue only one set of lights were on at a time. This kit keeps the low and high beams on at the same time. I know folks on the Chevy forum also essentially made the kit themselves. Whether this will overheat anything I don't know, but something to consider.
www.painlessperformance.com
Go to page 80 of their catalog - of course only mentions GM trucks, but I suppose you could write or call to see if they have any other applications or info.
Mike
Old Nov 27, 2015 | 04:06 PM
Dodgevity's Avatar
Dodgevity
I don't get this thread. Someone called "Mechanic" discovers headlight flashing at the stalk, which has been around on every vehicle for decades and decades. Then, there is talk of how to keep it turned on. I guess there is no consideration of how all this light will blind oncoming drivers. There are enough people running around with high beams on all the time.
Old Nov 27, 2015 | 06:31 PM
mechanic80's Avatar
mechanic80
Default Headlamp issue
Thanks, Mike for your help. I'll look into that right away. As for Dodgevity not understanding the question let me be a bit more clear: I live in the Manzano mountains of New Mexico. I DO NOT go around with my brights on in traffic. In fact there practically is no traffic. The winding country roads are a real challenge especially with the deer and coyotes popping up unexpectedly. I was hoping there was a safe way to keep both beams on at the same time without having to hold the stalk up before reverting lo beam operation. If this is still unclear to you please feel free to call me at (505) EAT- #&@#. Of all the clubs I belong to this is the only one with smart alec wiseguys like yourself. If you haven't anything helpful to say, don't bother to respond. BTW, if you think you're being clever not just a D%#K, you're wrong.
Old Nov 27, 2015 | 08:34 PM
Dodgevity's Avatar
Dodgevity
Relax, I wasn't trying to be a d1ck or wiseguy. My post was sincere. I simply found it highly ironic, given your moniker, that you were seemingly unaware of such a ubiquitous feature. The kicker was when you said "try it". Given that level of ignorance, why would I think it beneath you to drive around with the light filaments strung together, blinding people?
If you live in the sticks with lots of deer, attach a deer whistle and get some off-road lights instead of trying to burn out your wiring. No need to thank me... have a good day.
Old Nov 27, 2015 | 10:54 PM
00DakDan's Avatar
00DakDan
Section Moderator
** Moderator hat on **
The forum is a place for discussion. Watch the comments.
** Moderator hat off **
