Which actuator motor? air our floor vent problem.
Old Jan 17, 2016 | 01:07 PM
zeus661's Avatar
zeus661
Default Which actuator motor? air our floor vent problem.
I have an 02 Dakota with a heater problem. I can not get the air to blow out the floor vents only when set to heat on the floor. It comes out the dash vents also. I am thinking possibly an actuator issue but can not figure out which one. Any help with this would be appreciated. I figure someone here has had the same issue.
Old Jan 17, 2016 | 08:49 PM
00DakDan's Avatar
00DakDan
Section Moderator
The actuators are electric in your '02. It would be the floor/defrost actuator.
If the calibration is out you need a dealer to reprogram it - using their DRB III.
Old Jan 23, 2016 | 04:14 PM
zeus661's Avatar
zeus661
What would cause calibration to be off? Supposing that is the problem? Also can the dealer test to see what the problem is?
Old Jan 23, 2016 | 08:50 PM
00DakDan's Avatar
00DakDan
Section Moderator
It might have just failed.
Yes a dealer can check it with their DRBIII, and cycle all the actuators.
